configure mvr add receiver
configure mvr vlan vlan-name add receiver port port-list
Description
Configures a port to receive MVR multicast streams.
Syntax Description
vlan-name Specifies a VLAN name.
port-list A list of ports or slots and ports.
Default
N/A.
Usage Guidelines
This command is used to add a group of virtual ports for multicast forwarding through MVR. By default, some ports on non-MVR VLANs (router ports, primary and secondary EAPS ports), are excluded from the MVR cache egress list. This command is used to override these rules, so that if valid IGMP memberships are received, or a router is detected, streams are forwarded out on the ports.
The following example adds the ports 1:1 and 1:2 of VLAN v1 to MVR for forwarding:
configure mvr vlan v1 add receiver port 1:1-1:2
This command was first available in ExtremeXOS 11.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.1.1 Licensing Guide document.
